grama
I have a fresh water cooled marine engine with a domestic hot water system (electric pump and accumulator)............ When the engine heats up the domestic hot water and it
thereby expands......if you don't relieve the pressure (by using the taps)
where does the extra volume/pressure go? I know where mine goes because the pressure
relief valve operates and I have some water in the bilges by the calorifier. But
this can't be right. I don't want leaking water every time the engine runs. I did in fact fit a short
length of pipe from the relief valve to a collector bottle last year......as a tell-tale, but as
a temporary measure to save the water collecting in unwanted places. What sensible solution is there to this?
