Hot (very hot) from the cold tap
superheat6k
10 Jan 2012
South Coast
I've not investigated yet, but why / how did I get a continuous flow of mega hot water from all my cold taps today. The pump was running continuously, so not achieving system pressure, and every faucet was blasting red hot water from the cold taps.
There is a non return valve on the cold feed to the calorifier, but possibly stuck open I suppose.
I solved it by turning off power to the pump, vented the pressure, then re-started the pump which duly pressurised, cut out as normal and normal temperature returned.
Bizarre.
Snap. Same problem this weekend on our Hardy 42. I need to have a look at it next weekend.
My starting point is to check for low pressure on the accumulator; that would potentially explain hot water imbalance on the mixer taps, however we are also getting warm water coming into our fresh water loo, which is odd as that has a COD feed only.
I’ll follow this discussion with interest.
A brief investigation resolved three issues ...
1 The 27 year old check valve on the cold water supply was heavily scaled up and thoroughly stuck open.
2 The newly installed calorifier sits at a very slight angle creating a slight bubble above the high point hot water outlet.
3 This effect was made worse by the thermo reg valve I fitted having its regulated hot water outlet level with halfway down the tank.
So the fresh water pump was trying to push water in, but with the immersion on and set to max to get the maximum volume of regulated hot water, and with likely part of the immersion sitting in the 'bubble' I had actually created quite an effective steam engine. So the fully heated hot water was simply pushing back into the cold supply line and out of the taps, achieving a partially higher pressure than the pump could manage.
All below the relief valve pressure.
I have now replaced the check valve and remounted the reg valve so the hot water outlet is now the highest point.
A small bubble remains inside the gently sloping calorifier, and unless it continues to cause trouble there it will stay because remounting the tank at a different angle is another job entirely !
