superheat6k
I've not investigated yet, but why / how did I get a continuous flow of mega hot water from all my cold taps today. The pump was running continuously, so not achieving system pressure, and every faucet was blasting red hot water from the cold taps.
There is a non return valve on the cold feed to the calorifier, but possibly stuck open I suppose.
I solved it by turning off power to the pump, vented the pressure, then re-started the pump which duly pressurised, cut out as normal and normal temperature returned.
Bizarre.
Bizarre.
