Denngeor
New Member
Without boring you with the details, I managed to get sand into the combustion chamber. Several starting attempts were made prior to me knowing the sand was ingested. The motor did not start. Any suggestions to save the motor?
I think there are only two optionsWithout boring you with the details, I managed to get sand into the combustion chamber. Several starting attempts were made prior to me knowing the sand was ingested. The motor did not start. Any suggestions to save the motor?
Jamie,I'd not be alone in advising a total strip of the engine end of things, which isn't as awful as it might seem.
Page 52 (ish) onwards would seem to cover most of what you'd need to know, with the carb being a few pages earlier, and covered by this very detailed procedure. These aren't complex engines at all, and all spares should be readily available if you need them.
You do say "without boring you with the details"; go on, bore us with the details, all of us have these stories totellshare!
Unfortunately, the sea water entered the motor via the carburetor. Too bad the motor wasn’t fitted with an air filter but, I understand why you normally would not need one.If the motor wasn't running the sand and salt should only be on the outside. Perhaps clean any dried on salt deposits off the ignition system and try again.
