AngusMcDoon
I have a ratty much rusty old Honda BF2. This is not the current model because this one has an impeller, which now needs changing. I have got this far...
...but the drive shaft needs to come out to get the impeller off. The shaft is stepped so the impeller won't slide off as it does in sensible designs like Yamaha and Tohatsu.
It appears from here...
http://www.boats.net/parts/search/Honda/Outboard Engine/0/BF2AK SA/EXTENSION CASE/parts.html
... that the drive shaft (part 12) is simply splined at the bottom and should pull out, but for the life of me I can't shift it. Should it pull out? Surely I don't have to take the prop shaft out and the gearbox to bits just to change the impeller. If it's just stuck, how can I persuade it to unstuck itself?
