quatin
New Member
There was an e-ring holding the shaft to the lower assembly, but I popped it off easy enough. I have the shaft out separated from the extension case. What's the "water pipe" for in the extension case? What did you do with it when you added another extension case? The manual also says to add a hole for the "oil pipe hole" in L models only, so if I were to shorten it, think I should get a new bushing, but don't make the "oil pipe hole"?The 2 bolts that attach the prop gearbox to the shaft were removed, and the units simply separated. The shaft wasn't constrained at either the upper or lower ends, and 'slots' in & out of either end IIRC.
It required no engineering skill in either disassembly or re-assembly, just a spanner really, however as you'd know, getting the elongated shaft perfect is critical, and way beyond my skills level!
