lw395
Bilge Pump timers
I would not trust any software to run anything as critical as bilge pump on an unattended boat. No disrespect to the programmers here, but unless you have total confidence in every conceivable possibility, even the simplest software can have traps.
If you decide to do anything clever with a bilge pump, fit a second float switch higher up that is totally mechanical.
If you are into wooden boats that leak, a timer/counter circuit could be useful, to record how many minutes the bilge pump has run in your absence as the boat takes up.
A friend of mine invented a very nasty way of checking on a wooden boat. Get an old mobile phone and secure it just above the floorboards.
If you phone it and it doesn't ring, you have a problem!
AngusMcDoon,
I have read your posts with interest and admiration and would like to suggest another useful project to keep you busy this winter...
I have been researching simple timer circuits on the net to see if I could make a circuit to operate with a conventional bilge pump switch to control how long the pump stays on for.
This would enable the bilge to be emptied completely, reduce "cycling" as water in the pipe drains back and should help conserve battery charge.
It would enable the automatic bilge switch to be mounted higher. I'm looking for a circuit that is not "always on" and not gradually draining the batteryi.e the bilge switch turns on and then latches on for a certain time.
I'm sure there are commercial options but I'd like to take the "practical Electronics" approach.
Hope that makes sense.
Graham
