Chris_Robb
Following Easters delayed trip to deliver my new Oceanlord to Portsmouth from Ipswich due to starter motor problems, we did the journey in 2 hops, Ipswich to Eastbourne - started at 6 am and arrived 9 pm (103 NM), and then to Portsmouth on Sunday - arriving at 5pm. Motored all the way accept fo 15 minutes sailing when wind got up - sails like a dream
Arriving to huge welcome in Portsmouth
The crew
Not a bad voyage considering this was our first outing with her since purchase, however there are a number of faults which some of you may be able to help on.
1. ST 7000 (93 vintage) Autopilot reboots randomly, and occaisionaly peeps and adds or subtracts 5 degrees from course - we thought it was to do with the interfacing of the GPS because when it was turned off it didn't do it - until it did. So any ideas? perhaps low voltage on old wiring?
2. Locking gear lever in reverse to stop prop spinning under sail resulted in a jamed gearbox - release by starting engine in reverse. (Volvo 2003T) Can you leave it in gear to stop the prop turning?
3. Engine start batteries - crap - 15 hours of motoring and would not start the engine. Voltages at engine batteries under way never rose above 13.2 V - so should I fit and Adverc or Sterling smart regulator? Original owner always had shore power and a 4 KVA generator - so probably never noticed.
4. Anchor chain is joined at 25Mtrs to another length with shackle, total 50 meters - can they be joined safely with 2 part link joiners?
Not too bad a list really..... Now just to find a new name for her, so change of name in process from Mary Penelope to Carina (on Part1).
The crew
