Sixpence
The rumoured name change, I beg to report, is just that, a rumour
And the moral of the story is ..........
Ouch !!! Whats the story Dave ?
What happened?!!!!!
Sorry just seen your new post.
Just as well ply glassed hulls are not too difficult to repair then.
At first glance I thought you were installing an anchor well thru' the hull.
Hope you have lots of epoxy lying around.
Good luck, it's always tragic to see a boat damaged that way.
Told you that cardboard wouldn't work Dave.![]()
Git
Well hopefully the repair work so far will prove to be better than last time
Hole is now an ex hole, with the first coating of two part epoxy over it, and a coating of two part epoxy resin will go over that before antifoul, though I think the barnacles may well have held the hull together a bit
suggest a poly tent Dave with a fan heater inside to speed / ensure cure time
