Chris_Robb
Since I installed my holding tanks in 2010, I have had nothing but problems with the pump out system, which is a Jabsco tyoe diapragm pump with jocker valves. I am now onto my third pump, as none of the pumps have ever managed more than a weeks pumping without stripping down cleaning and rebuilding- not a job you want to do every week!
So first likely problem from Jabsco - jockers done up too tight. Tried all pressures - makes no difference.
When the pump fails to prime (DIp tube of approx 500mm into tank bottom.) I take it to peices and the jocker valves are not tightly sealed but slightly gaping. The effect at the suction end is to get a suck puff suck puff situation, which should of course not happen.as the jokes are just not sealing (I have tried many new ones.)
So what should I now fit. The Jabsco macerator has a max priming head of 600mm. It would fit in the area with some new piping as it discharges into a smaller bore.
I am not happy with Jabsco at all as they have been extremely unhelpful apart from new pumps which dont work!
