nigelmercier
RIP
- Joined
- 20 Jun 2007
- Messages
- 16,234
- Location
- Live in Kent, boat in Canary Islands
Further to my thread about excessive belt-belt spacing between a pair of crankshaft pulleys, just over 3mm wider than the twin alternator pulley.
I made the boss to fit each side of the pulley: one with a groove, one with a ridge. This clamps in my lathe chuck, and the pulley bolts onto the respective face.
Having reduced the outer part of mating outer faces by a total of about 3mm, I'm in the position suggested above.
I planned to do one of these:
(1) glue it to the boss with cyanoacrylate glue. I'm sure I've read this works, but worried about release.
(2) countersink the bolt holes and use countersunk M8 screws.
(3) make a smaller boss that just covers the hole and hold it with the tailstock, or a center screw. Remove ridge by hand.
Thoughts?
So, if you are bolting this to an ally bung, or using a bolt and washer through the middle, how do you propose to machine both faces accurately to each other? At some point you will need to remove the bolts, find another clamping method and perform a second operation.
Thoughts?
