pirate
New Member
still rebuilding 7 ton hillyard but have now reached a point where some advice wouldnt go amiss.have replaced rotten floors and mast step and now need to replace numerous cracked frames.i have removed the coverboards on port side
ready to lower new timbers in.my main concern is the gaps between the planks where the boat is dry!from reading the books it would appear the next step is to rake all of the seams
remove every other timber to allow the planks to be pulled back together with straps and then steam in and fasten new timbers!!at certain parts of the hull there is a 1/4 inch gap between planks and at others no gap at all.the boat has been re caulked before which i think may have caused the problem.
if i do tighten the planks back together (remembering they are dry)will they swell when wet to a greater extent than when the boat was built in 1930 and crack frames?if you think its ok to pull all the planks back until the inside edges just touch then i know how to carry on.thanks for any advice
