high tide times Poole
You don't get Times for HT at Poole Low tides are
Fri 10 0446 1702
Sat 11 (Springs) 0521 1736
Sun 12 0553 1808
Mon 13 0624 1840
All times GMT not summertime
I'm sure you could work out roughly when HT is from this but it is a double high tide at springs
High tides for that weekend are
Fri 10th 10.26 (2.22M) 22.42 (2.23m)
Sat 11th 10.52 (2.21m) 23.12 (2.19m)
Sun 12th 11.29 (2.13m) 23.43 (2.09m)
Mon 12.00 (1.98m)
SWMBO just read them from the tide book so should be right (I did get her to check she was reading from the right year)
It's no good trying to plan that far ahead, you know the weather will be absolute crap that weekend with it being a bank holiday /forums/images/graemlins/frown.gif
I would be worried, she might have had the correct year but knowing you use the wavey line tide tables was it the right way up!!!
You know her mind is firmly fixed on the NEXT sale for tomorrow. /forums/images/graemlins/grin.gif
We get HT times published in out marina's booklet too, but they are not very accurate because it is so unpredictable inside Poole Harbour. They are not published in Reeds either. They suggest using LW and then approximating from the tidal curves
Just had a go at that and it shows Fri as HT 0821-2021 GMT. Interestingly, even with HT at 2.2m, there will be 8 hours from 0621 up to 1421 where the tide is over 1.5m (well I thought it was interesting)
They are not taken from the marinas booklet they are taken from theTidal Planner you get from piplers and one from N.j. Clake publications they both show the same and seem ok.
Mon 12.00 (1.98m)
Poole has a double high tide a couple of hours apart and often very variable, so not covered by this response. There is only a single low water, which is why this is what is usually published.
I have sent you a PM with the tide book so that you can see for yourself that the times are right , we use them all the time to work out if we can get under the bridge , they seem ok there is no blue paint on the roof of the boat.
I hope this helps you
