High Thrust prop?
Inselaffe
18 Jun 2003
Lisboa
Hello,
Some one told me on here that a high thrust prop for my yamaha 9.9 hp 4-stroke
would look like mickey mouse ears, is it possible to say if my prop is high thrust or not from the picture?
[image] http://uk.pg.photos.yahoo.com/ph/leighsutherland67/detail?.dir=5064&.dnm=9960.jpg [/image]
the numbers are illegible, but I'll take it to the local outboard shop if I'm asking too much from a photo only, but I'm also using this post as a test for trying to get photos to work!
LEigh
Inselaffe
18 Jun 2003
Lisboa
Sorry - first time using Yahoo to post pictures on net.
have just found sharing settings and made it accessible to all
should work now....
greatspirit
16 Aug 2004
West Wales
I have definitely got a high-thrust prop on my Yamaha 9.9 will measure the pitch etc on my spare at the weekend and post
Regards
Tim
Aeolus_IV
24 Apr 2002
East Sussex
Click on help, then option 27 <A target="_blank" HREF=http://www.ybw.com/faq/2.22.htm>Mark up Tags</A>. Its all explained there.
Regards, Jeff.
<hr width=100% size=1><A target="_blank" HREF=http://users.swing.be/FDB/centurion/index2.html>Centurion 32 Web site</A>
Inselaffe
18 Jun 2003
Lisboa
that's what I tried to follow, but what is the variable for the actual url you want to use?
I deduce that you substitute the actual url for the word 'link'.
this works for
<A target="_blank" HREF=http://link> description </A> = Only the url's description shows
but then if I want to show the picture the FAQ say's
[image] url [/image] = Shows the picture
but theres no variable 'link' here. I tried replacing 'url' with the url but it don't work, and it isn't consistent with above.
It's not very clear to me which is the actual syntax and which are the bits that you type in.
Also of course there is the high probability that I have missed something glaringly obvious!
Inselaffe
18 Jun 2003
Lisboa
that link works in my browser!
I'll try another though, this time without spaces:
So that's what it is.
No mention that the spaces given in the example in the FAQ shouldn't be there.
And the position in which you type/paste the url in is given as 'link' in most examples and the word 'url' must be left as is, but in the '[image] url [/image] = Shows the picture' example 'url' is where you type/paste the url in.
Shouldn't it read '[image]link[/image] = Shows the picture' and spaces that are important to be left out shouldn't be there?
Maybe I'm being pedantic (and probably wrong) but otherwise it doesn't make sense to someone like me who hasn't ever used suchlike before?
BrendanS
11 Jun 2002
Tesla in Space
That link is probably already cached on your computer, which is why it will display if you try it, either that or you need to be logged in as the user to access it.
It's def a dead link from here.
<hr width=100% size=1>Me transmitte sursum, caledoni
alahol2
22 Apr 2004
Portchester, Solent
www.troppo.co.uk
From memory of my old Yam 9.9 I'd say that is the high thrust prop.
They come in 2 or 3 different pitches and can be aluminium or plastic.
<hr width=100% size=1><A target="_blank" HREF=http://www.troppo.co.uk> Follow the Tightwad Sailor</A>
