Hi. Fender lines
CFG98
8 Jan 2021
I am returning to sailing now I am retired. Boat is at side of house having a spruce up. Have decided to renew grotty nylon fender lines. Thought I would ask what type of line others use. Type of rope, length, diameter, colour etc etc. Recommend a seller? My largest fender is three foot long. 26 foot boat. Probably 3 foot freeboard. Dont want to spend lots on fender lines but don’t want to spoil ship for tuppence of tar either or look silly in a marina.
Braided 6 or 8mm polyester would be ideal, don't use polypropylene as although it's cheap and floats does not withstand UV degradation. Length to suit, either an eye splice to the fender or a bowline.
10 mm three strand spliced onto your fender and a backsplice on the other end to make sure that if your knot slips you don't lose your fender.If you can't splice then now is the time to learn a new skill.
bought a few packs of pre spliced soft 3 strand (nylon?) from chandlers when on sale, cow hitched to fenders otherwise used bin ends on sale whenever, wherever like Jimmy Green's stands at boatshows.
A set of grotty, mismatched fenders can do wonders for keeping undesirables from rafting alongside. A few baby clothes drying in the rigging will compete the look and ensure an absence of trampling feet after closing time...
More seriously, I had crew whose knots weren't to be trusted, so my fenders have cheap snap hooks set at the appropriate length for each position and are numbered 1 to 4, to be clipped on forward of each stanchion. They work in 90% of situations and mean lines and fenders can be sorted a good bit quicker, which is particularly useful when single handed.
All good. An offcut from the chandlery will suffice but avoid line you know will be slippery, or fenders will go overboard. 10m would be optimal for larger fenders. Length sufficient to allow fender to lie on water, then fenders can be doubled up horizontally for protection against harbour piles etc.
PWG
To complete the look, the ends of the lines should be fraying. This is easier with three-ply, and the look that I favour. Just occasionally, I will accede to aesthetic sensitivities by wielding some amalgamating tape or doing sailmaker’s whipping. The only considerations for the lines are ease of handling and abrasion resistance. I use plain polyester but I wouldn’t claim that any other is wrong.
I don’t like the idea of clips. I check my crew’s knots. She checks mine.
Quite right. Our boat is a working mans recreation, not a rich mans toy with paid hands to keep it shiny even when the owner is long absent. Fenders are functional , to be jammed between wharf and boat then put away when sailing. Ideally only the fender board should be seen above deck when on the water and even that must succumb to functionality over aesthetics
My 4 main fenders have lines attached at both ends so that they can be used horizontally. The 'bottom' rope is normally half hitched to the 'upper' rope when used vertically. Anyone else use the bottom eye?
One catamaran I occasionally skipper locally uses the lower hole of the fender. Some thin line and a plastic clip is secured to each one. Instead of taking ages to stow fenders and rig them again 4 hours later, my crew simply lift the fender horizontally and secure them with clip to guard wire. Simple and outside the wires so free gangway for the punters.
I like this idea. A friend of mine who is now a bit old and a bit dodgy on his feet quite often asks me to take him out on his boat, a very tidy Beneteau 331. So I rigged drop em and go dock lines and put those clips on the fenders, 9 of them. As it's normally only for a few hours, it's perfect.
Might do that on my yacht for short trips round to anchor off the beach. Easy life.
