Hfl generator issue
Thank you, I have downloaded the manuals. It gives a part number for the key switch so I’ve emailed HFL to see if they can supply one.
But failing that, it appears to be a simple 2 position switch, off and on so I would think an alternative key switch should be relatively easy to source.
Hi
If you PM me your email address, I will send you a link to the manuals that I have, which were a pain to get hold of...
Hi John, maybe it's a long shot but is this manual still available please? I have been searching for it everywhere and am going crazy now. Thanks
Yes, no problem, I will send you a link shortly to allow you to download from our server, I will keep it open for a day or so, just let me know once you have downloaded it on here please.
John
Hi John,
Yet another request for your manual/notes if possible please.
Mine will start and will run for various periods of time and each time I think I’ve fixed it and then it inevitably stops 15seconds later. It can’t be serious as it always restarts and works perfectly as far as producing electricity is concerned. I suspect that it has to be a sensor that is knocking the fuel pump relay off.
Many thanks in advance.
Hi yes, of course, no problem I had huge trouble many years ago tracking down a manual. If you PM me your email address, I will send you a link to my server so you can download the HFL and Engine manuals which I scanned in PDF format.
If the Genny has been disconnected, or left/unused, for a long time you may just need to flash the rotor winding to re-charge the capacitor. It is a relatively simple process described in the manual IIRC.
Hi John
I also have bought a HFL h2w6m1c 6kW but no controller box, so if you could send me diagram for the cabels I really appreciate
Lillebjerrum@hotmail.com
Thanks in advance
Hi John
Is there any chance I can grab a copy of the hfl manual as well. Got a problem with trying to reflash an old H1N 3.5, everything else seems to work fine just no output and capacitor has no volts
After working fine for a while mine has decided to cease to function.
It's seems to be fuel starvation,it will start but not pick up and then cut out, there's a good flow to the injector pump so I'm thinking it may be the stop solenoid stuck.
Anyone had that?
