Bigfoot00
Hi i'm new to the site and have a project about keel bolt sealing washer and i posted on another part of the forum help where i was told to post here.
here's the full question please help
The drawing entitled "sealing washer for keel bolts states that the washer is required to be made from a "good quality rubber". it also quotes an obsolete reference to a specific material "dTD 625".
A) Investigate a range of suitable materials from which component could be made. You should use at least 3 different sources of information, for example, electronic (internet CD-ROM), paper based and "expert" recommendation. Identify what information you found from each source. Outline the difference between the suggested materials and the reason for your choices, including their appropraiteness for making the component.
