ferrispeterchris
The email address for enquiries is (inquiries@gasketstogo.com) and his ebay name is qualtrough2004. Hope this helps. As I said previously there is a massive saving pricewise using the ebay guy.
Are you sure? I have an MD1B and am lead to believe the only difference is that the "B" has a reverse gear. I think it states that in the manual.MD1 head gasket is different from MD1B. Different bore diameter. I couldn't source one either alone or as a set. Engineer in troon found one gathering dust under his bench, but nobody stocks them anymore.
Photo of gasket - i'm guessing the apertures in the exhaust port at the engine should replicate the gasket?
Hi Vic ( I was chatting to you about SeaWyches) Head Gaskets can still be found. I boughta "decoke set" from "Keypart" a couple of years back,not cheap at £63 but beggars can't be choosers. I then Hydraulically Locked the engine by putting the exhaust manifold gasket on the wrong way round! Difficult to do but I managed it! I then found an American guy in Thailand (on ebay) who made them in copper at $35 well worth the money and posted quickly.
To the OP, if you are going to take the head off I will try to contact him if you want,PM me. Peter.
