skyflyer
I have a project using an Arduino that outputs NMEA0183 sentences through it's serial port. This, if i understand correctly, uses the RS232 protocol whereas NMEA0183 equipment does not and it needs to be converted to what I believe is the TTL protocol.
I have ben advised that the us elf this chip http://www.farnell.com/datasheets/76791.pdf will do the job, but being a complete electronic novice I cannot make head nor tail of that data sheet to work out war I have to wire to which pin etc.
The chip I have been told to get is a MAX232EPE.
Can anyone help or suggest an alternative method?
At the moment the arduino is writing perfect NMEA0183 sentences and sending then down the wire, but the instrumentation is not able to read it and I am assuming that this is the reason - something to do with inverting the signal?
Thanks in anticipation as always!
