merlin3688
Sailspar fill the rivets up with the little plastic plug spoken about earlier although Z spars just leave it blank. I guess puting the plug in looks better.
Buying a decent rivet gun need not be expensive, I recently brought 3 guns, all that could take 1/4 pop rivets for very little money on Ebay, they were all second hand but worked just fine. Avoid the cheapest ones as they will work for 5 mins or not pull up the larger rivets.
I was taught that rule of thumb that you need 3mm length of rivet through the material, shorter and it will pull up in the material and longer it will not pull up tight.
