gary111160
I've been on the boat for the last 10 days or so and used the D4 for hours on a daily basis. No problems, even this morning. Go to switch on just now and its not working.
It starts up as normal, fan then ticking from the pump, then a bit of warm air and then shuts down. Try it again and the same happens.
All thats changed is the amount of diesel left. Gauge shows quarter full and this is lower than I have let it go in the past but the gauge reads less than I actually have.
I can see diesel pumping into the unit when the pump is ticking as every so often a buble will move along the clear tube up into the heater. Not sure thats a good thing.
If it was'nt for the fact that it fires up each time I would have thought fuel problem. But it starts just wont continue to run.
Had a similar problem two years ago and the diagnosis was the brain (or thats what they called it) replaced and it went fine. Cant have gone again so soon. Cost around £200 from memory.
Any advise or observations?
Cheers
Gary
Cheers
Gary
