Jabamusic
I know not another one, but please your assistance would be gratefully received.
After 3 years in storage, I now have a new (to me) boat to install my old D1LC compact into. With winter on its way, it will be a great asset I'm sure.
Anyway, whilst I thought I'd removed and stored it nicely, unfortunately the controller (a 401.00 191) is damaged beyond repair. I have got another, but the wiring is quite different.
The 401 has 6 wires coming from it, whilst the new one (a 7 day, 1 hour timer I believe) only has 4 wires coming from it.
The 701 has RED, BROWN, YELLOW, RED/GREY.
The 401 has RED, BROWN, GREY, YELLOW, BLUE, BROWN/WHITE.
To complicate matters the old controller was wired with an external thermostat, so the Brown/White wire and the Grey wired are spliced out to a choc block- the Grey from the ECU is spliced to the the blue of the Thermostat and the Brown/white to the brown of the thermostat. The Brown/white wire is then led fed back into the connector.
My question is what do I connect to what?
I assume
Blue = diagnostics
Red + ve
Yellow = Signal
I have attached a photo or 2 to help out. The first two are the switch loom heading to the ECU, the last 2 are from the controller into the switch loom.
I am happy to lose the thermostat if necessary to simplify things, although if it can stay all the better.
Very much appreciate any help, suggestions, advice.
Jaba
I assume
Blue = diagnostics
Red + ve
Yellow = Signal
Jaba
