Kittycarter
My carb has been serviced as the accelerator pump had broke. The carb was refitted and the connection to the automatic choke was repaired ( it hadn't worked since I had the boat). It worked fine the first two times.
When I started it myself the engine goes straight to full throttle no matter what I do with the throttle lever. Everything has been checked outside the pump, apart from the choke.
Does anyone have any ideas?
I am convinced the automatic choke is at fault, but any help would be gratefully received.
Sean
Sean
