paul1084
Hi all,
I have an old MD1 with the RB type gear box (I think).... I use a 33c type control cable for the throttle which works fine. I am trying to attach a control cable for the gear shift (F/N/R). On top of the gearbox there is a short stainless steel horizontal bar with a threaded hole in the side at the end. pushing the bar forwards or backwards selects forward, neutral and reverse. I purchased a new 33c Control cable, fabricated a bracket at the right height/distance to mount the cable, attached the end to the bar... the threads match, and then mounted/connected the other end to a lever. Now the lever pushes/pulls the bar, but no where near enough to engage the forward or reverse gears.... its clear that I need more than 3" of travel on the control rod.... I think it could also do with being a bit stronger, as the gear lever is quite "clunky" and requires some force to push into gear.
Does anyone know what control cable I should be using for this engine? I assume the threaded hole in the gear lever is standard and has not been added as an addition, so it must have been designed with a control cable in mind. I have trawled the internet, and can find no conclusive information, the RB gear box seems to be quite rare, most appear to have a different setup altogether.
Please help!! any help will be much appreciated before I aimlessly plummet more money into this old engine (Which runs beautifully by the way
Paul
Paul
