demonboy
I'm about to embark on some further research into generators for our 43ft boat and I've been chatting to the boat yard about fitting one in order to charge our 405aH battery bank plus run a water maker that I have not yet purchased (so there are some missing variables).
However as a first port of call I thought I'd ask you clever people for your comments/thoughts on what my boatyard in Turkey has come back to me suggesting. Here's what they said:
I have looked at the 4 and 7 kw generators and we can fit the 4 kw only. So you must calculate while you are buying the rest of the equipment you need.
The generator is Onan 4.0MDKAU 2 cylinder, 4 kw, 220 v,18.2, 50 hz with 2400 rpm.
The cost of this generator is $9145 (€7620) including VAT. This price also includes the water lock, cables, siphon breaker, control panel and sound insulated cabin.
Onan is probably the quietest generator around and easy to find spare parts for.
Zeynom and Blues both had 11 kw Onan generators installed last spring and they are very happy.
Onan is manufactured by Cummins Engine and because it is an American company the prices are in dollars which means a great buy because the dollar is so low right now.
Installation of the generator including water intake, new exhaust, fuel line, electrical link, polyester and carpentry work, commissioning of the engine and a running track under the generator will be around €3000 plus materials.
Because the generator will be sitting on top of the steering quadrant compartment we will make a sliding track under the generator so that you can move it aside to get at the steering gear and to reach the sides of the generator.
It is the beginning of the season and there are only a couple of this size generators left in Turkey right now. A new shipment is not expected for some months and I have a 48 hour option on it. I know it is not much time but if we want the generator I need to put a deposit on it.
Any comments appreciated!
