Otter
This is driving me nuts!!!
I've got a new Cobra F57 VHF radio, it's replacing an old Cobra, the old one displayed position. It gets GPS from the Matsutec AIS transceiver which sends NMEA position to a bus from which the Raymarine system gets position data - all working fine.
The Cobra comes with a plug with three wires, NMEA in +&- and a ground/shield but the manual shows a plug with only two wires and the Jack part only has one ring, this one has two.
I have the old Cobra NMEA in plug.
1. If I use the new plug, wired correctly it screws up the bus, nothing gets NMEA, with or without grounding the shield wire.
2. If I use the old plug that also sometimes screws the bus, sometimes not, either way neither plug gets the radio to display GPS.
Now I'm remembering my old Garmin days where they used three wires, didn't you have to join the NMEA - to ships negative 12v? But the manual is clear, you have a two wire NMEA system on this radio.
Anyone able to help? I thought NMEA was the one flipping part of the boat I understood
