help me source a linear actuator for my generator governor
vas
21 Jun 2011
Volos-Athens
title says it all really (except the specifics of the query)
yanmar motor is ready, fired up, works now on first or second turn of the starter motor.
as discussed in another thread I want to alter the way it operates so it doesnt fire up at 3K rpm straight away and doesn't stop from that rpm either.
Further more the fuel stop solenoid that was a b1tch to bleed the fuel pump is playing up not letting all the time the right amount of fuel through, so it is removed and discarded. Means I need to find a way to stop the thing and I aint gonna use a wire to pull and stop it for sure.
So a new classic mode stop solenoid is around 60-80euro and I'm still left with the rpm up and down to solve.
Now, if I remove the governor stop (or anyway undo it all the way) the engine will stop anyway, so thought of getting a decent linear actuator and kill two birds with one stone, bear with me:
Fully extended governor at 0 point lets say, engine off
Slightly retracted from 0 point governor at around idle or thereabouts, engine starts
After a minute or two, actuator pulls governor to 3K rpm, a relay closes the electrics (ARE mentioned something I have to check when testing regarding where I cut the circuit in the first place) and 220V power is established
On switching off, relay opens, no 220V output, actuator extends to idle position and after a couple of mins extends further turning the thing off.
All easily accomplished with an arduino board and a few bits I already have.
Now what I'm missing is the linear actuator.
Used a fish weight measuring thing my late father had somewhere in the garage (must be 40+ yo...) to establish the power of the governor spring, it's around 6kg so say 60N, and since I don't like things working on their limits, I'd like a 200-250N linear actuator
Travel with be around 30mm maybe 35, so say 50mm or 2inch travel.
These two properties are reasonably easy to find and fairly cheap for a 12V setup, china 30-50quid
HOWEVER what these dont have is a feedback sensor aka a potentiometer giving a Ohm output which the PLC or arduino would read to know where exactly the thing is.
I'd really really like to avoid getting yet another rudder sensor and stick it in (btw the rudder sensor working to tell me when gbox is engaged in FWD or REV is working fine...) so I'm after:
A linear actuator with:
50mm (2inch) travel (could accept more, just will be cumbersome to fit on the side of the yanmar, and pointless)
200-250N (could do more but rather pointless...)
12V
slowish speed (say under 30mm/s-preferably less)
and feedback potentiometer (aka not a 2wire actuator but probably a 5 wire one)
any pointers welcomed!
BTW, LINAK don't do such small things (or I'm missing completely the plot and happy to be corrected)
blimey, you're extremely efficient in finding things! Everytime I'm after an obscure thing you're the first one sourcing it.
I wonder if I should bother posting on the forum or just PM you straight away :D
thanks FARSCO, I'll go for two sizes up so P16 for the higher forces available and the slower speed, but definitely that's what I was after!
now to decide where to get it from (if they have in stock the combo I'm after that is...)
cheers!
V.
hm, your google is better than my google :p
I'd obviously googled that as well before...
Good thing is that robotshop has the one I want on stock 91quid VAT included.
V.
Great! How will you work out the position it’s in?
I saw they supply a LAC board to plug a usb into. All the stuff you do is black magic imho:)
I'm a poor person, cannot afford the LAC :p
nah, don't really need it, I'll just use a 5euro chip that does the swaping of the + and - to retract after extending the thing and then with some trial and error establish the feedback sensor values regarding where I want the actuator for stopping for idling for fast idling and for 3K rpm operation.
The dodgy bit will be when (and if!) I decide to start checking the Voltage and Hz produced by the generator under heavy load vs idling to alter governor position accordingly but it's not really necessary atm (and possibly ever...)
I need to have something to keep the brain spinning (that's my excuse at least) :D
V.
