Help identifying calorifier please
anyone know how to disassemble these fittings ?
The ones to the right of the picture with grey insert rings - push the ring and the pipe together inwards towards the fitting to get the steel internal teeth to let go of the pipe. You can get a little C-shaped plastic tool to help hold it all the way in, all the way round, which is necessary to get it to disengage. Maybe pick one up at Wickes or B&Q if you're there anyway, but should be able to do it by hand if not.
The other ones I don't know. It's possible they don't have a release mechanism at all and will have to be cut off and replaced.
I don't know whether you've sourced your calorifier yet.
I got mine, which looks like yours (but not bursted I hope!) from these people.
http://proof.stoneboatbuilding.co.uk/20ltre-calorifier-vertical-single-coil.html
There's no picture on the website but if you sent them a pic of yours with approx dimensions they could tell you if the one they sell is the same.
As you say without the pics on site, it is a little unclear.
Pretty sure now mine is a cleghorn waring version (now c warm) - probably very little difference between one copper cylinde 20 lt capacity and another. My boat is a 33 footer pretty big internal volume so I am debating at present whether or not it is worth upgrading to the twin coil version for the added input of a diesel heater at some stage.
