KevO
The heads area in our Hustler is getting overhauled in accordance with the latest promulgation of SROs (SWMBOs Routine Orders). As can be seen below, the compartment is pretty cramped and currently has a Jabsco compact loo and a 'pull out' sink unit. The sink unit drain is simple... you pull out the plug (no pipes connected to it) and the waste water just falls into the loo bowl below to be pumped out. The top part of the loo seat assembly has been removed (leaving just the seat
) to allow for this.
SWMBO wants a new, regular sized Jabsco fitted and the full seat assembly used. Therefore the sink cannot just drain straight down into the bowl (cos the lid's gonna be in the way). I am (apparently) allowed to reposition the sink as required to allow the new loo and plumbing to be fitted which is a bonus I'm sure you will agree.
Anyhoo... the old heads and sink unit etc is coming out, old waste pipes too, then the seacocks stripped down and serviced. Bulkheads are to be faced with new modern pattern formica (chosen by guess who) and the new loo fitted as per instructions. So... does anyone have any bright and practical ideas about how I can refit the sink and connect up the sink drain so that the waste water can be got rid of safely (without fitting a new skin fitting)?
