ghostlymoron
Going back to the original problem, if it didn't exist in the past, you must consider what has changed or what has been done to cause it. For example, have the filters been changed? If so, and air leak could have been caused by this. (I keep banging on about air leaks from filters because your symptoms are exactly what we experienced). If you have dismantled some of the fuel lines, the problem could be with a joint misaligned or slightly loose. I think the comment about proper fuel clips being used instead of jubilee clips is unlikely to be the cause of the current problem as presumably the fuel system has been working satisfactorily for the past 15 years.
