NormanS
The only time that I ever had a problem with the engine dying when slowed, it was a dirty fuel filter.
I have a 3 cylinder beta 20, about 15 years old
After it has been running continuously at medium to high revs for about 48 hours it cuts out when the revs are dropped to approach a berth. It has done this twice after long windless Biscay crossings. It has also done this after a 6 or 8 hour passage
Coming into a harbour is not when you want your engine to cut out
The filters are clean, the tank is clean, the idling speed has been adjusted to run smoothly. The engine runs perfectly at high speed then it just dies as you slow down
I thought I had cracked it today by slowing very gradually but it still died
All advice very welcome. We still have another 700 mms to get home
I used to have a similar problem. I found the tick over speed was a bit low. I adjusted upwards a little and I no longer have the engine cutting out going from highish throttle to neutral.
Mention of valve clearances early in the thread baffled me. Yes, it is reported that incorrect valve clearances can cause eratic idle. But I have run and worked on many, many engines over the years and never come across one which had a running problem resolved by adjusting tappets.
Big clearances can cause poor performance and starting. Tight clearances can cause burning of valves, but the symptoms only appear once the damage has been done. In either case either the rattling or the banging and popping would alert you.
I'd definitely suspect a fuel supply problem. Probably the injector pump/govenor rather than the fuel line.
We had a similar problem last year on the river rhone. The engine would run fine at 1500rpm but would often cut out when we slowed to idling when passing through a lock. It turned out to air leaking in at the CAV filter which was cured by tightening it up more. (there was a long thread on here last year)
Also after 15yrs, it would be wise to check your tappets.
Don't discount it because it's difficult. References to air leaks are surely limited to the ingress of air into the fuel line. Air for combustion just falls (is sucked) into the cylinders and unlike a petrol engine inlet air leaks don't effect the fuel/air ratio.First under the microscope will be the fuel system then the tappets. I suspect that the govenor may be a bit too complicated.
WHY
if there isn't a problem don't fix it
He stated no oil being burned no noisy tappets
these old diesel engines are basic things not high performance racing, change the oil regular grease any thing that needs it but leave well alone
it could be as simple as poor quality fuel or an air leak due to high temp causing things to move no way is it tappets or low compression
I'm not suggesting tappets are the cause of the current problem but 15yrs is a long time without adjusting them. Refer to your manual. I used to adjust tappets on my morris minor every 3 months and that wasn't a racing car either.
What does that mean? The Morris Minor handbook did recommend checking the tappets at every service and they had often changed since the previous one.read it in a book did you
