oceandrive
I have fitted to the boat Predator 92s based in Balearics a Dometic air con system, the boat has two chillers / heaters and 13 handlers so "chilled water system". the system has a dehumidifier option so that during the winter the handlers will work as Dehumidifiers.
My question is do I need to run chillers or Heaters or just the handlers. local agents just looked blank when I asked them using my best Spangalish which is not too good.
Also the forward handler in the saloon can run as a windscreen heater but I have lost the detail on how to program this. I know I have to put the chillers into heat mode for this.
Can any forumites who may run a similar system or work with such systems help please.
