Dtwo1946
Active Member
I’ve posted a couple of times recently about the transom on my boat being raised to accommodate the long shaft Yamaha outboard that’s on it. I got some really helpful replies but some seemed to think that the boat was designed for a short shaft motor whereas I was under the impression that it needed a standard shaft.
The boat is a 1970s Aqua Jeep built by Chartermark Marine.
Can anybody out there give me a definitive answer so that I get the right shaft length whether I replace the whole engine or just the leg and drive shaft? Standard shaft or short shaft?
I don't know how to estimate the leg length required by measuring the gap from the transom top to the waterline because it's twin hulled. When it comes up on the plane the bottom of the hull centre may be marginally out of the water at high speed. Any advice on how to estimate it if nobody knows the answer?
