Lyndon
I eventually got round to fitting the hella regulator to my new engine this weekend(Yanmar with standard 55amp Hitachi alternator), the problem being that the instructions state that there should be two wires (red and black) to attach to the batteries to sense the battery voltage and temperature, my regulator has a red wire and a white wire so I naturally assume that red +ve, white -ve. If I attach the wires to the battery the alternator stops charging but if I remove the white wire it seems to work as it should.
I know it's a long shot but does anyone know if running it like this is likely to cause any problems?
