Tim Good
Do you know what make/model the inverter is ?
Heart Freedom 20.
There should be no reason that the inverter won't run the heating element, it's a purely resistive load and will only work at the power rating that the inverter can supply.
I might be missing something, but it seems to me you're trying to draw 166 amps out of the battery, assuming 12V. That's a lot of current, and you better be sure the wiring, connections and battery are up to it, or else you're doomed to failure.
You are missing something, about 34 amps. As i said earlier, a 2kw inverter under full load will draw about 200a. But you're right about one thing, it's a lot of current.
I worked it out as i=P/V which equals 166A. So where am I wrong?
Reference? I understand there are losses, but 90% is way beyond my experience.Doesn't translate literally where inverters are involved. Accepted rule of thumb is Watts/10 for 12v.
Summary:
I want to heat my 2kw calorifier using my 2kw inverter but it won't work.
Details:
This season I've been using the inverter a lot more as we are able to generate way more power on solar than we can consume now that we're on the coast of Portugal. We always boil the kettle now on the inverter and I'm looking for more things to use.
For hot water, when the engine hasn't been run we fire up the webasto. However, I figure we could use the inverter. However the calorifier is rated at 2kw and so is out inverter. When I switch in the calorifier it simply doesn't activate when the inverter is on. I assume this is because the inverter just says "no it's too powerful".
I doubt the calorifier needs a pure some wave, which my inverter doesn't have.
So my question is can I buy some kind of in line resister that I install in the positive lead to the calorifier which will reduce its power to something like 1.5kw?
What you need is a voltage regulator available from RS components part no. 655-644, no major loss of energy & select what rating you want from the element , will handle up to 15amps,have used them for several year for this sort of application
Jim
Jim
Yeah deffo. It works on shore power and when the generator is on. I wonder if something was originally installed in the system to prevent someone accidentally turning it on when inverting.
Jim
For the hard of understanding, can you explain in laymans terms what this item does and how it held the OP. Many thanks.
Heart Freedom 20.
It's almost certainly a thyristor (or equivalent) dimmer, like those used for lights on a bigger scale. Basically they don't switch the power on until a particular stage of each cycle.
Works fine with a sinusoid, but as VicS says may get a bit upset by the stepped output of a lot of inverters.
