Mistroma
doesent work the microwave thou![]()
I suppose you could always hoist some bread up to the radome if you want "Toasty". Perhaps not.
reading the thread on heaters made me wonder what size inverter i would need to run a small
fan heater in my wheel house whilst under way?. i have seen this one http://www.ebay.co.uk/itm/281022258134?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
on ebay, which doesn't seem a bad price for 1500watts. would it be enough, be handy if it could handle a
microwave as well. obviously it would run on the engine battery whilst running.
I am currently bench testingThis finding was forewarned on the forum, apparently the 15 mm tubing in the unit does not transfer heat very efficiently. I will persevere with it as the boat is small and it will be difficult to install anything bigger.
Indeed, matrix are not efficient with diesel boilers due to the lower coolant temperature, a number of times when I have installed the boiler in circuit with the engine, using temperature controlled diverters they work well when its the engine heating the coolant but dissapointing when run on the boiler even with insulated hoses. As you have it now you could try slowing the flow with a valve, gradually balance it to just below max shut off by the boiler. Especially in the controlled situation you are in it should be easy to fiddle, this can produce an improvement and you can easily measure the difference. The good ones made by Kalori and sold by the likes of Kuranda & Mikuni (two of my distrubutors) are much better as the 16mm inlet and outlets branch into smaller tubes internally, still not perfect but better. Until somebody comes up with a proper matrix with a header tank at each end and lots of very small tubes I can't see any real improvement. Car Builder Solutions sell a matrix box which uses a car heater matrix and that matrix meets those criteria, I am considering getting one to put on test but won't hold my breath, its more about the actual coolant temp, or rather the difference between the ambient and coolant temp.
Thanks for the info. I think it was yourself who advised earlier that these heaters were probably not great performers. I contacted the supplier and returned the unit, upon which he advised that the number of fins was less than normal. He replaced it with another but its performance is little better. His diagnosis is that the flow rate is insufficient, which I do not agree as the whole circuit, including the headers each side of the matrix, seem to be at similar temperatures.
There is little point comparing with vehicle haeters, consider this, the average diesel boiler will run in the upper 60s / lower 70s when installed, the average car will run between 85 and 95 depending whether petrol or diesel. Also consider this, a 3l engine can generate 23kw of waste heat.
http://www.nrel.gov/vehiclesandfuels/ancillary_loads/pdfs/2002_01_1969.pdf
Hi all,
I was interested to read the idea of using a car heater matrix. My boat (MF805) has what is essentially a Toyota land cruiser engine so I could imagine that fitting a car type heat exchanger might be simple enough.
Does anyone have some more information on this type of installation?
thanks
rich
Just plunb it in with a feed and return tapped from the calorifier circuit (parallel not series) , put a couple of valves (or at least one on the return) so you can balance the flow rate, it should perform OK when the engine is up to temp but the wheelhouse / saloon is a big area for a car matrix, that's why mini busses have auxillary heaters in the back.
