trouville
N/A
While everyones thinking about sun shades, im heading towards the artic circel!(it starts halfway up the Finish coast)
Im told the Baltic spring/autum nights can be chilly so i want to install a vented heater.
I thought of takeing my Talors diesel, but aboard a small Folkboat it would be to big and to hot!! I also dont want to cut a large hole in my cabin roof,nor suffer the sooting around the outlet.
A force 10 parafin one would be ideal but cant be bought in Europe? So im going to make a small heater!
Hear you see that a dripfeed heater has a 3inch chimny but the parafin only a 1 inch chimney, the same 1 inch for LPG heaters?
http://www.taylorsheatersandcookers.co.uk/sp079db.html
JUST FOR EXAMPLE: If i attach a 1 inch tube to a 12 inch heater caseing, then under that put a 2200w camping gas stove, would all the fumes and damp vent via the chiminy? after all its then just exactly the same configeration as a Talors of Force 10 unit.
Now if instead of the pressurised heat sourse, i place a simple 2000w alcohol wick fed "fondue" heat source under the same heater body why shouldent the same 1 inch chimney vent the simple wick burner??????????????????????????????????
If its to do with the gas flow, then then wouldent the lower out put of the wick still permit sufficent gas flow as the pipe walms up?
Or is the 3 inch pipe needed to ensure soother burning of the raw diesel fule in the burner pot?
Will a 1 inch chimney flue vent my heat sourse removing water vapor and carbon monoxide??? It works with both Talors and force 10? /forums/images/graemlins/confused.gif
