BruceK
Okay - I placed the after cooler in a bucket of brick cleaner and after about 10 mins I thought there was a fire with the smoke from the cleaner - lifted the exchanger out which was very warm and thoroughly rinsed and found a couple of the side fins disintegrated - placed on 2 bricks and with the plug in placed I poured the brick cleaner in and left it for a hour.
then I rinsed it out several times and then several times more.
I will be ordering o ring kits tomorrow - does the plug that screws in at the bottom require any sort of ptfe tape or does this just screw in as is ?
Oil cooler next to strip down.
Jon
OMG Jon. I told you to stand it up and pour the descaler in like it was a bucket . The charged air cooling fins are not brass nor ever meant to see any cooling water, the core is and does. Were the fins corroded before you dumped them in acid? There was a pic posted in one of your threads by some chap whose cooling fins had rotted away. The core should be readily easily and cheaply repaired with new cooling fins from a specialist, particularly in the KVAC and refrigeration field. Post up pics please
Jon
With Rydlym you have the option of pumping it around insitu. From a................
Much better to strip and rod. You dont have to put items in a bucket per se to give them a rince in Rydlym or brick acid before rodding. They are a bucket of sorts already. Just stand them upright and fill. (Note I wouldnt use brick acid instead of rydlym when insitu on the engine, just on the brass cores)
......................... in efficiency
As for the plug in the bottom, that is a tapered brass bung. Check it very carefully for any dezincing (Like you'd do for seacocks). One of mine crumbled like kiln dried clay on removal. It was quite an eye opener.
