No Regrets
Fifty Shades dropped back in the water on Friday, Thanks to a lovely little crane job from the guys at Penton Hook!
Both engines started immediately, pumping water fine, and were freshly serviced...
Twenty minutes later, exiting the marina, the Starboard engine was overheating, so was shut down, and appeared to have lost nearly all the (new!) coolant....!?
The bilges showed nothing at that time, so the engine was refilled, and the calorifier valves closed as a precaution, and an hour later things seemed OK, so we went back to Bray, watching those gauges like a hawk...
Thankfully, the problem didn't come back, but when I opened the calorifier valve, the coolant all disappeared again within seconds, and so I reckon it's a pipe failed somewhere in the front, near the calorifier, which is good news because a/ I can fix that, and b/ The likely part alone was over £2000 (Heat exchanger stack) plus removing engine to fit, as the forward bulkhead is too close to remove it.
The big old Volvo is healthy though, as I just caught the overheat at the upper end of the engines normal heat range, but it could so easily have killed the engine if I hadn't noticed the problem in the first place. A sobering thought as a new engine is probably around £25K
So, next week, a little job....
Rather glad to be back at Bray on time, as the next morning everything was redder than election time in Oldham....
