scrambledegg
**sorry, applies to mainsail, not headsail **
I've been having trouble hoisting my mainsail (~25 m sq) all the way to the top without using a winch, so I thought I would reduce friction by swapping the deck mounted plain-bearing 50mm turning block for a ball-bearing one of 60mm. It turns the halyard through 90 degrees.
I see now though that the ball-bearing blocks have lower safe working load that the plain-bearing ones. The one I bought says 300kg on the packet (but 500kg in the spec on the website, confusingly).
I mainly cruise the boat but I'm hoping that the racers on here might know what are normal luff tensions for mainsails, related to wind strengths.
