Hydrozoan
^^ Perhaps my point was a too fine. … A lot of variables, to be sure.
I understand what you are now saying, but had in mind your observation “Actually, no biological matter is required” at #68, which I thought a potential cause of confusion.
I’m sure you are right that organic matter on hose walls might provide an adequate food source for hydrogen sulfide production. But so may organic matter from land run-off or from in-situ marine production (which are likely often to produce much higher levels of both dissolved and particulate organic matter than in your marina tap water, for example) so that cross-contamination with the heads discharge side is not necessarily a precondition for hydrogen sulfide production, even were there to be no great build-up of organics on the intake hose.
