Ian MacAulay
Afternoon, I have a 4.3 mercruiser carb'd engine. Im not up on carburettors to be honest and no nothing about them. But having not long had the boat is it worth having the carb checked and set up correctly, to make sure its in tip top form for right mixture and performance? Also does the timing need to be checked...if so should it be done regular?
My limited knowledge is all with more modern ECU controlled engines that tell you if something wrong with a light or a buzzer
Ian
Ian
