Have I got a leak?
  • Thread starter Thread starter alt
  • Start date Start date
alt
24 Oct 2006
Éire
Spotted this today on the manifold of my KAD300.
Presume that's a leak from the coolant sensor? (Located at the back of the manifold, under the Turbo)
Temp seems fine so presume the sensor is fine... but wondering if I should change it while the manifold is out (changing manifold gaskets). On marinepartseurope it just shots a stop cock there?!
OR, should I just change the copper washer? (presume it's a copper washer... looks like one!)
The washers are listed on Marine Parts...
Volvo Penta Exploded view / schematic Electrical System: B KAD44P-C, KAD300-A - MarinePartsEurope.com
Seema sensible to me to remove, repaint and refit the sensor.
tbh you can never be sure if the new replacement washer has been annealed or still work hardenned from the stamping process so it's good practice to re-anneal them anyway. If yours has not deformed from over enthusiastic tightenning then it may well have been put in without annealing it from the go. I'd simply re-anneal in that case by heating to a dull cherry red (done in low light) while suspended from a wire and not pliers ( heat sink) for a minute or two then drop it into water to descale it. Check all the mating surfaces are clean and even and re use. If you're buying a new washer you should be doing this anyway
So, loosened earlier and it loosened a bit too easy, so I do suspect there was a leak there. Took BruceK advise (also advised by a local guy on-site), cleaned everything up and re-seated (nice and tight this time).
I cleaned up the nut to try and get a part no. For anyone who may ever need to replace this sensor, the OE seems to be: VDO 805/38/1 (Max. 150 degree C)
