vic008
Hauled for 2-3 months. How long and how often should I run the engine? 3 cylinder, fresh water cool, Vetus.
Can you explain how running antifreeze through the engine helps the exhaust elbow? Really would not want any water left there for the reason you explain later. The water drains into the waterlock, so would prevent that from freezing in extremely low temperatures. If that were likely i would be much happier draining the raw water system completely and emptying the waterlock.Good to know there is no need for temperature protection.
There are differences with a boat on the hard vs being in the water for 2 months - maybe not enough for some to be concerned about, but enough for me. The purpose of inhibiting with a/f in the raw water system means the engine doesn't need to be run at all any further, and it adds corrosion protection (useful for those that have cast exhaust elbows).
I left my Nanni 14 for 8 years drained of raw water and emptied the fuel tank. Changed the oil and filter, hooked up a water supply added fresh fuel and it started instantly.When I leave my boat ashore it is for six months, unattended. I carry out similar pre-layup actions as others have described but it is then left entirely. During covid it went three years without running but started in about 10 seconds of turning over.
There is quite a lot of evidence that running occasionally for short periods is particularly poor for diesel engine life, although less so since sulfur levels in fuel have reduced.
Hi, sure.Can you explain how running antifreeze through the engine helps the exhaust elbow? Really would not want any water left there for the reason you explain later. The water drains into the waterlock, so would prevent that from freezing in extremely low temperatures. If that were likely i would be much happier draining the raw water system completely and emptying the waterlock.
I agree with all of that except that I am sceptical of any benefit of running a small amount of cold antifreeze through the engine in the hope that some of it will reduce corrosion in the elbow. The elbow spends all its life being attacked by hot salt water and combustion residue and after running the antifreeze solution it will do nothing to remove those corrosive elements and just evaporate. Equally in temperate climates like most of southern UK and New Zealand there is zero chance of anything in the cooling system freezing. Of course there may be localised conditions where freezing is a possibility and precautions may be needed. I leave my boat in the water all year round and in the last 30 years even in Poole the sea has frozen more than once but I have never seen temperatures anywhere near freezing in the engine box.Hi, sure.
On small engines with cast iron exhaust elbows, as you know the water is injected into the elbow for cooling prior to mixing. Sea water and diesel exhaust fumes forms a mild caustic mix that accelerates corrosion.
As anti-freeze contains corrosion inhibitors, running this through the engine helps to coat the elbow and slow down the process.
In addition, there are often bigger temperature swings in the the engine rooms on the hard as opposed to when in the sea. The ocean acts as a heat-sink and stabilises the temperature swings. Without the sea surrounding the boat, the temperatures can vary a surprising amount and this leads to condensation forming on the metal parts. Add in the relative humidity being higher in winter, if the exhaust isn't capped off and the valve train is open even slightly, the exhaust mixing elbow on a cold boat is not a nice place to be with cold, damp air swirling around.
I have pulled apart engines and found traces of water damage on main bearings which has been attributed to condensation droplets in the engine. Running the engine for short periods does not generate enough heat to evaporate the condensation, it will actually contribute worse as a small amount of heat is generated and then the engine is shut down which allows more condensation to form due to the temperature differences. It will do the same in the exhaust. This is one reason why the statement from a previous post is correct that it is actually worse to run an engine for short periods.
I agree that the benefit is marginal at best, but a flush through with fresh water is definitely better than leaving salt water there for corrosion, and the a/f does help mitigate the increased risk of fresh water freezing. It certainly isn't a silver bullet, but it's one less cut to bleed.I agree with all of that except that I am sceptical of any benefit of running a small amount of cold antifreeze through the engine in the hope that some of it will reduce corrosion in the elbow. The elbow spends all its life being attacked by hot salt water and combustion residue and after running the antifreeze solution it will do nothing to remove those corrosive elements and just evaporate. Equally in temperate climates like most of southern UK and New Zealand there is zero chance of anything in the cooling system freezing. Of course there may be localised conditions where freezing is a possibility and precautions may be needed. I leave my boat in the water all year round and in the last 30 years even in Poole the sea has frozen more than once but I have never seen temperatures anywhere near freezing in the engine box.
