AntarcticPilot
Capricious is a Moody 31 Mk II, and I'd like to fit a shower in the heads. She has a calorifier, and it would be a simple matter to replace the tap unit with a suitable mixer tap with a shower head. But the tray in the floor of the heads, although fitted with a nice teak grating, has no drain, and is very shallow, with no obvious access below it (and possibly little space below it; Moody 31s are quite flat bottomed aft).
Has anyone fitted a drain system to the heads in a Moody 31? What I have in mind is a pump to be fitted in the vanity unit under the hand basin, connecting via a T piece and a non-return valve to the outlet for the hand-basin. Is it possible to put a neat drain in the bottom of the tray? I can't see any way of getting access at present, but is it possible at all? Otherwise, I will need to put a strainer box in the bottom of the tray. A submersible (or partially submersible) pump would be too bulky; there isn't that much space.
Anyway, if anyone has done a project like this, I'd be interested in your experiences!
