Has anyone come across this before?
andyangler
11 Mar 2009
Hi all,hoping someone can help.When i first put my boat in the water(norman 20 with 70hp 2 stroke yam) WOT was around 23knts the last 3 or 4 times i been out she will only do 12knts,tried carb cleaner 2day and when i was testing it i noticed when i was doing 12knts WOT as soon as i turned right she went straight up to 23knts.I slowed down and then it would only go back to 12knts again.Turned left and nothing,turned right again and straight back to 23knts.Has anyone have any idea what this could be?Its driving me mad plaese help.
Andy
exfinnsailor
18 Jul 2007
Kink or collapsing fuel pipe .. When you turn to starboard it straightens out a little and lets more fuel through .. Mind you whats wrong with going everywhere at 12 knts .. We go most places at 5 .. /forums/images/graemlins/shocked.gif
Richard Shead
Slipped Anchor
14 Aug 2007
Time Inc.
from the brief description it sounds like its not getting on the plane however when you turn it will sometimes climb onto the plane.
Simple test take two mate out, sit on the bow and floor it, if this does not work then there is something more to it. Has the boat been in the water long if so where and is it prone to growth, even the smallest amount of growth will effect the performance.
andyangler
11 Mar 2009
It in cardiff bay which is fresh water so i dont thing there would be to much growth,it been there for about 5 months.I can see what your saying but it only happens when i turn starboard?
Richard Shead
Slipped Anchor
14 Aug 2007
Time Inc.
It will always pull more one way, try the weight distribution once more you will be amazed how much junk you accumulate on the boat in no time at all.
If that does not work then they may be something else (obviously!) and of course report back
andyangler
11 Mar 2009
checked fuel line and no kinks found,someone has said maybe a sticking float in the carbs,do you think this is possible?
Richard10002
17 Mar 2006
Manchester
sure its not the fuel line,
Are you sure because you have watched the whole length personally whilst turning to starboard, to see if it straightens out, or becomes uncrushed, or unkinked, or whatever?
or are you just sure? /forums/images/graemlins/smile.gif
Firefly625
18 Mar 2009
Home=Surrey / Boat=Hamble
not sure that excess growth on hull would give the effect experienced by the OP, goes 23knots on a right turn, 12 knots straight or to left..
to the OP, do you have trim tabs fitted? (is one not working correctly?)
Has the Prop or Skeg been damaged?
Has the outboard been off the boat and then re-fitted a bit too far off centre....(although all single engined outboard boats should be mounted every so slightly off centre to counter act prop effect), but if too much might have this effect.
Sounds more like fueling issue... like everyone else has mentioned, but if you believe it not to be a kinked fuel supply pipe... is fuel clean, are you low on fuel. Have you a fuel filter with water separator? Does it need draining? I assume the engine rev's pick up mighty when on a right turn? Or is the engine just really struggling all the time apart from when turning to the right? If so is the boat incorrectly loaded? Is it listing too far to the right?
....or its might be an electrics issue... but I am going to have to think about that one as this is a bit unusual!
any of this helpful?.. /forums/images/graemlins/confused.gif
Richard Shead
Slipped Anchor
14 Aug 2007
Time Inc.
All good comments and suggestions but I am going for the weight issue and standing by it!
Please report back on your findings (don't try it tonight though!)
andyangler
11 Mar 2009
ok,the engine has not been removed from the boat and there is no trim tabs fitted.I have 30l of fresh fuel in tank which was only bought yesterday.Will remove fuel filter 2morrow and clean.the do pick up loads when i turn right and then she takes off!I dont think the boat is incorrctly loaded but will also remove everything from the boat just to rule this out.
Firefly625
18 Mar 2009
You never know, the OP may have a torch? ! /forums/images/graemlins/wink.gif
Firefly625
18 Mar 2009
Andy..........good luck... the fact that the engine really picks up when on right lock does indicate an interruption of power when doing anything else apart from turning right...... whether that be fuel or electrics or simply a throttle linkage / cable issue. I would have a check on anything going to the engine!!
