Harken Pawl Gear Needed
The Bronze gears have worn down, about 0.5mm on both cogs.
Makes an awful noise but the winches work perfectly.
Not a lot you can do, but they are unlikely to fail completely if you keep them greased. Do it regularly and find a thick and sticky grease. Check out open gear lubricants, as there are some made to stick in place better than ordinary greases.
Yes if we are looking at the gears.
The pawls should be oiled, not greased! Harken supply, at yacht spares prices, both the oil for the pawls and the grease for the gears.
And obviously replace the pawls and their springs often. This is a dead easy job on a workbench and less so on a cockpit coaming with the rain coming in sideways!
I've used WD40 on all my Pawls, for years (on various boats) and never had any problems with them. Thanks.
