Martin_J
Just seen this thread for the first time just now.. I also find it hard to believe the lower threaded section has just 'pulled out a bit bearing in mind that the lock nut does look to be a 'lock nut' which is purely threaded on the lower section. And it is now tight up against a locking washer and the drum.
The odd threads do look like old damage.
You say that the mast is simply lowered and then stepped again for the summer..
Did the riggers this year perhaps find that it was a struggle to reconnect the backstay... and their simplest option might have just been to lengthen the forestay by a couple of inches to allow the backstay to reach?
