solent clown
RIP
Next task as we get the mast and rigging set up is to convert jib to roller furler. Is there an easy way to do this ourselves, or is it a sailmaker only task?
I have the furling gear, and wife prefers it, hence the question. I will take the sail to our local sailmaker and have an ask then. Kiwi slides look interesting, might have a try with a spare sail just for experimentation
The sail will probably have to be radically recut. Hank-on sails are generally made with their foot close to the deck, whereas the roller-furling type have their foot angled upwards, so that the clew rises as the sail is rolled in.
The smart roller looks great as a furling option but I can't see it reefing very well as the top can unroll under tension .
Running a second stay behind a furler can cause tandem tension probs .
If you don't intend to use the furler that's fine .Some sail accidents have occurred as a result of the Hank on sail being rolled into the furling sail ��.Primarily when running .
Adding a stay and other attendant fixings (halyard block etc ) usually more hassle ,unless you can set it flying .
