Buck Turgidson
I have a large overlapping Genoa (125 %) on a roller furler and a couple of older but good hank sails. One about 100% the other a storm jib. If needed I hoist a wire stay on my second Jib halyard and hoist the sail using the spinnaker halyard. This sets like a solent with the temporary stay just aft of the forestay on a very secure pad eye.
Sails stripped for the winter.
I'm contemplating using the older 100% jib this season for no other reason than curiosity but don't want the expense of converting it.
What's the simplest way of setting a hank-on sail around the forestay blade without damaging it?
My thoughts so far are to hoist the temporary stay(5mm steal) between the upper and lower swivel points and hoist the sail using the second jib halyard or use a series of soft shackles on the hanks.
First runs the risk of buckling the blade. Second of denting it at the point loads. Not sure if either is realistic but I'm brain storming so everything is valid at this point.
Any other suggestions?
